 [TABLE] Tron Legacy
snwfrd38
Département : Allemagne
MessageSujet: [TABLE] Tron Legacy   Lun 18 Déc 2017 - 18:22
Salut tout le monde
J'ai un probleme sur la table de TRON - le DOF ne se charge pas et il me met le message d'erreur (dans B2S).
System.Exception: DirectOutput framework has encountered a exception during setup.
Inner exception: Could not load file or assembly 'Ciloci.Flee, Version=0.9.27.0, Culture=neutral, PublicKeyToken=fc11e355737f8b7f' or one of its dependencies. The system cannot find the file specified. ---> System.IO.FileNotFoundException: Could not load file or assembly 'Ciloci.Flee, Version=0.9.27.0, Culture=neutral, PublicKeyToken=fc11e355737f8b7f' or one of its dependencies. The system cannot find the file specified.
  at DirectOutput.FX.ConditionFX.TableElementConditionEffect.GetVariablesInternal()
  at DirectOutput.FX.ConditionFX.TableElementConditionEffect.GetVariables()
  at DirectOutput.LedControl.Setup.Configurator.SetupTable(Table Table, Dictionary`2 TableConfigDict, Dictionary`2 ToyAssignments, String IniFilePath)
  at DirectOutput.LedControl.Setup.Configurator.Setup(LedControlConfigList LedControlConfigList, Table Table, Cabinet Cabinet, String RomName)
  at DirectOutput.Pinball.Setup(String GlobalConfigFilename, String TableFilename, String RomName)
  --- End of inner exception stack trace ---
  at B2SServerPlugin.Plugin.PluginInit(String TableFilename, String RomName)
  at B2S.Plugin.PluginInit(String TableFilename, String RomName)
Dans le repertoire TABLE (de VPX) j'ai les fichiers suivants:
B2STableSettings
ScreenRes
Tron Legacy (Stern 2011).VPX
et
Tron Legacy (Stern 2011).directb2s
Le fichier B2STableSettings contient
Code:
<B2STableSettings>
  <ArePluginsOn>1</ArePluginsOn>
  <DefaultStartMode>2</DefaultStartMode>
  <LogPath>
  </LogPath>
  <IsLampsStateLogOn>0</IsLampsStateLogOn>
  <IsSolenoidsStateLogOn>0</IsSolenoidsStateLogOn>
  <IsGIStringsStateLogOn>0</IsGIStringsStateLogOn>
  <IsLEDsStateLogOn>0</IsLEDsStateLogOn>
  <IsPaintingLogOn>0</IsPaintingLogOn>
  <IsStatisticsBackglassOn>0</IsStatisticsBackglassOn>
  <ShowStartupError>1</ShowStartupError>
  <ScreenshotPath>
  </ScreenshotPath>
  <ScreenshotFileType>0</ScreenshotFileType>
</B2STableSettings>
Je suis sur une reinstallation fraiche des VPX10.4 (beta 3).
Merci d'avance pour vos idees,
Fred
snwfrd38
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 13:53
Je galere toujours autant sur cette table pour le DOF!
J'ai meme refais une installation complete du PC:
  • win 10
  • VPX 10.4 (Beta 4)
  • DOF R3+ (de MRJNET.ORG)
Mes cartes:
  • 1 Mega 2560 en Ledwiz (LEDWIZZ 1 dans le DOF)
  • 1 KL25Z avec Pinscape (PINSCAPE avec PINSCAPE 1 dans le DOF)
  • 1 Tensy (TENSY avec TENSY_ID 1 dans le DOF)
Tout marche sur ces tables pour ACDC, Baywatch... La seule qui ne fonctionne pas est TRON.
J'ai enleve la table / rom / b2s et je l'ai reinstalle (en prenant les versions d'ici dans la centralisation des tables)
Je galere a mort pour cette table. Toute aide sera la bienvenue!
Le message d'erreur dans le B2S qui montre un probleme avec la dll. Pourtant cette DLL est installe / pas de pb de mode UNLOCK / je l'ai meme copie dans plusieurs repertoires pour voir.. Rien de rien... le DOF ne fonctionne pas sur cette table (dans ma config!).
Quelques nouvelles!
  • Les contacteurs (sur la carte MEGA en mode LEDWIZ) fonctionnent très bien sur la table TRON
  • Les lumières des boutons (sur la carte PINSCAPE) NE fonctionnent PAS sur TRON (mais très bien sur d'autres tables)
A priori le probleme semble être autour des fichiers de Config du DOF!
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 16:38
Sujet déplacé au bon endroit
Quel version de la table ?
Mon monde:[Vous devez être inscrit et connecté pour voir ce lien]~YouTube [Vous devez être inscrit et connecté pour voir ce lien]Tutos:[Vous devez être inscrit et connecté pour voir ce lien][Vous devez être inscrit et connecté pour voir ce lien][Vous devez être inscrit et connecté pour voir ce lien][Vous devez être inscrit et connecté pour voir ce lien][Vous devez être inscrit et connecté pour voir ce lien][Vous devez être inscrit et connecté pour voir ce lien]Ventes:[Vous devez être inscrit et connecté pour voir ce lien][Vous devez être inscrit et connecté pour voir cette image]
snwfrd38
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 16:45
Merci [Vous devez être inscrit et connecté pour voir ce lien] :-)
Version 1.3F de la table [Vous devez être inscrit et connecté pour voir ce lien] ainsi que le B2S et la ROM (174H de mémoire)
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 16:47
Essaye la version PUP Edition pour voir Question
snwfrd38
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 17:25
Idem - les 2 versions PUP font le meme resultat...
En cliquant sur le B2S --> il me met une exception
et pourtant en utilisant le DOFTEST tool on peut voir que:
  • la carte PINSCAPE et bien reconnu sur le port 51
  • Le fichier DIRECTOUTPUTCONFIG51 et bien la
  • et que dans le DOF CONFIG tool on la voit aussi...
et sur la Table ACDC avec la meme config....ca marche tu tonnerre
et baywatch idem ca marche aussi...
c'est fou non ???
Pour info voila config du pinscape (en mode pinscape uniquement et pas LEDWIZ - cf 1e copie d'ecran)
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 17:59
T'as essayé avec le dof r3 normal , pas celui de mjr ?
snwfrd38
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 21:21
@peskkopat : oui a l'instant et c'est pareil. J'ai remis la version de MJR.
Dans le doute j'ai repasse
  • la PINSCAPE en mode Ledwiz #1 et la Mega2560 en Ledwiz #2. Changement du DOF / effacer tous les fichiers de l'ancienne configuration / copier les nouveaux fichiers  ca donne rien non plus...
  • La Pinscape en Mode Ledwiz #2 et Mega en Ledwiz #1 - idem
  • et finallement la pinscape en mode PINSCAPE #1 et la mega en Ledwiz #1 - idem
Je galere grave et je suis sur que c'est une connerie que je vois pas!
Si dessous le LOG du fichier lorsque j'utilise TRON
Code:
This is the mjr modified DOF version R3+ 2016-10-19
2017.12.23 20:51:32.306 DirectOutput Logger initialized
2017.12.23 20:51:32.306 DirectOutput Version 0.9.6136.25325 as of 2016.10.19 14:04
2017.12.23 20:51:32.306 Global config loaded from: C:\VISUAL PINBALL\DIRECTOUTPUT\config\GlobalConfig_B2SServer.xml
2017.12.23 20:51:32.306 Loading Pinball parts
2017.12.23 20:51:32.306 Loading cabinet
2017.12.23 20:51:32.307 Will load cabinet config file: C:\Visual Pinball\DirectOutput\Config\Cabinet Config.xml
2017.12.23 20:51:32.395 1 output controller defnitions and 4 toy definitions loaded from cabinet config.
2017.12.23 20:51:32.395 Cabinet config file has AutoConfig feature enabled. Calling AutoConfig.
2017.12.23 20:51:32.395 Cabinet auto configuration started
2017.12.23 20:51:32.405 Debug: Disposing LedWiz instance -01.
2017.12.23 20:51:32.405 Detected and added LedWiz Nr. 1 with name LedWiz 01
2017.12.23 20:51:32.406 Added LedwizEquivalent Nr. 1 with name LedWiz 01 Equivalent for Ledwiz Nr. 1
2017.12.23 20:51:32.406 Detected and added LedWiz Nr. 2 with name LedWiz 02
2017.12.23 20:51:32.406 Added LedwizEquivalent Nr. 2 with name LedWiz 02 Equivalent for Ledwiz Nr. 2
2017.12.23 20:51:32.426 Detected and added Pinscape Controller Nr. 1 with name Pinscape Controller 01
2017.12.23 20:51:32.426 Added LedwizEquivalent Nr. 51 with name Pinscape Controller 01 Equivalent for Pinscape Controller Nr. 1, 22
2017.12.23 20:51:32.426 Cabinet auto configuration finished
2017.12.23 20:51:32.426 Autoconfig complete.
2017.12.23 20:51:32.426 Cabinet config loaded successfully from C:\Visual Pinball\DirectOutput\Config\Cabinet Config.xml
2017.12.23 20:51:32.426 Cabinet loaded
2017.12.23 20:51:32.426 Loading table config
2017.12.23 20:51:32.426 Warning: No table config file found. Will try to load config from LedControl file(s).
2017.12.23 20:51:32.426 Will try to load configs from DirectOutput.ini or LedControl.ini file(s) for RomName trn_174h
2017.12.23 20:51:32.427 Loading LedControl file C:\Visual Pinball\DirectOutput\Config\directoutputconfig.ini
2017.12.23 20:51:32.430 Min DOF Version is 0.8 for file directoutputconfig.ini
2017.12.23 20:51:32.540 Loading LedControl file C:\Visual Pinball\DirectOutput\Config\directoutputconfig2.ini
2017.12.23 20:51:32.541 Min DOF Version is 0.8 for file directoutputconfig2.ini
2017.12.23 20:51:32.726 2 directoutputconfig.ini or ledcontrol.ini files loaded.
2017.12.23 20:51:32.728 Config for RomName trn_174h exists in LedControl data. Updating cabinet and config.
2017.12.23 20:51:32.732 Debug: Disposing LedWiz instance 02.
2017.12.23 20:51:32.834 EXCEPTION: DirectOutput framework has encountered a exception during setup.
2017.12.23 20:51:32.834 EXCEPTION: Thread:
2017.12.23 20:51:32.834 EXCEPTION: Message: FileNotFoundException --> Could not load file or assembly 'Ciloci.Flee, Version=0.9.27.0, Culture=neutral, PublicKeyToken=fc11e355737f8b7f' or one of its dependencies. The system cannot find the file specified.
2017.12.23 20:51:32.836 EXCEPTION: Stacktrace:    at DirectOutput.FX.ConditionFX.TableElementConditionEffect..ctor()
2017.12.23 20:51:32.836 EXCEPTION: Stacktrace:    at DirectOutput.LedControl.Setup.Configurator.SetupTable(Table Table, Dictionary`2 TableConfigDict, Dictionary`2 ToyAssignments, String IniFilePath)
2017.12.23 20:51:32.836 EXCEPTION: Stacktrace:    at DirectOutput.LedControl.Setup.Configurator.Setup(LedControlConfigList LedControlConfigList, Table Table, Cabinet Cabinet, String RomName)
2017.12.23 20:51:32.836 EXCEPTION: Stacktrace:    at DirectOutput.Pinball.Setup(String GlobalConfigFilename, String TableFilename, String RomName)
2017.12.23 20:51:32.836 EXCEPTION: Targetsite: Void .ctor()
2017.12.23 20:51:32.838 Finishing framework
2017.12.23 20:51:32.839 Finishing cabinet
2017.12.23 20:51:32.840 Debug: Finishing output controllers
2017.12.23 20:51:32.840 TeensyStripController MulticolorLedStrip finished and updater thread stopped.
2017.12.23 20:51:32.840 Debug: Finishing LedWiz Nr. 01
2017.12.23 20:51:32.842 LedWiz Nr. 01 finished and updater thread stopped.
2017.12.23 20:51:32.842 Debug: Finishing LedWiz Nr. 02
2017.12.23 20:51:32.843 LedWiz Nr. 02 finished and updater thread stopped.
2017.12.23 20:51:32.844 Pinscape Pinscape Controller 01 finished and updater thread stopped.
2017.12.23 20:51:32.844 Debug: Output controllers finished
2017.12.23 20:51:32.844 Cabinet finished
2017.12.23 20:51:32.844 DirectOutput framework finished.
2017.12.23 20:51:32.844 Bye and thanks for using!
avec les log on voit qu'il n'arrive pas a charger la DLL CILOCI.FLEE pourtant elle est la!
Dernier essai - je viens de virer le fichier "directoutputconfig" - celui de la LEDWIZ 1 donc du PINSCAPE en ayant laisse le ficher "directoutputconfig2" de la LEDWIZ 2 donc de la MEGA.
TRON fonctionne parfaitement - le DOF aussi - mais je n'ai plus les effets sur la LEDWIZ 1 (eclairage des LED sur les boutons...). Bon il semblerait que ce fichier "directoutputconfig" soit le probleme....
Je pars demain pour la France pour les vacances de Noel en famille. Je regarderais ca a mon retour (le 2) cependant si vous avez des idees je suis preneur car la je seche grave! PS: J'ai deja re-installe le PC (reset total) avec re-installation de tout le package VPX / DOF and co... Donc je pense pas que ca vienne de la...
C'est bien le fichier qui merdait!
en enlevant chacun des elements un par et en recreant la config ca fonctionne. Le probleme (et j'ai aucune idee du pourquoi) est que la config RGB UNDERCAB COMPLEX est le coupable. En mettant RGB UNDERCAB SMART la table TRON fonctionne!!
J'essaye de suite les autres tables ! Quelle aventure ca fait reellement 2 semaines que je me prends la tete sur ce truc!!!! Les autres tables semblent fonctionner correctement -> Je passe en RESOLU --> @[Vous devez être inscrit et connecté pour voir ce lien]  il me faudrait une nouvelle balise "RESOLU mais il ne sait pas pourquoi".
En tout les cas je pense que ce poste peut servir a d'autres! Bon noel a tous - je peux partir en paix avec moi meme et mon pincab
Dernière édition par shadow_shd le Sam 23 Déc 2017 - 21:57, édité 1 fois (Raison : messages successifs fusionnés)
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 22:02
[Vous devez être inscrit et connecté pour voir ce lien] le multipost à quelques minutes d’intervalle c’est diablerie
Messages successifs fusionnés et content que ton problème soit résolu Wink
snwfrd38
MessageSujet: Re: [TABLE] Tron Legacy   Sam 23 Déc 2017 - 22:23
Merci Shadow et bon reveillon!
MessageSujet: Re: [TABLE] Tron Legacy   Dim 24 Déc 2017 - 11:19
Bien joué @snowfrd38 , content que ça fonctionne , bon réveillon
mikuslegrand
MessageSujet: [EN COURS] table TRON LEGACY   Lun 26 Mar 2018 - 22:30
bonjour à tous les passionnés,
voila j'ai commencé l'installation de tables pour VPX mais j'ai un souci avec la table TRON LEGACY.
j'ai un message d'erreur, est ce que quelqu'un à déjà eu ce problème. ( voir ci dessous )
si quelqu'un peut m'aider ca serait trop cool car j'ai trop envie de jouer à cette table.
merci  [Vous devez être inscrit et connecté pour voir cette image]
bono
MessageSujet: Re: [TABLE] Tron Legacy   Lun 26 Mar 2018 - 23:24
bonjour, regarde si tu as bien mis la ROM trn_174h dans ton dossier ROM comme indiqué plus haut dans le script
mikuslegrand
MessageSujet: Re: [TABLE] Tron Legacy   Mar 27 Mar 2018 - 0:11
Oui j'ai bien la rom de mise dans le dossier.
je viens de tester la rom avec vpinmame et le dmd s'affiche bien sur mon écran.
je comprends pas d’où ca vient et la j'ai le même souci avec la table indiana jones stern 2008.
je sais pas si c'est une coïncidence mais les 2 roms contiennent des fichier.bin, on dirait que j'ai un pb avec ce genre de fichier.
merci de m’éclairer Wink
MessageSujet: Re: [TABLE] Tron Legacy   Mar 27 Mar 2018 - 18:50
C'est du Stern la tron donc il faut le sambuild de chez vp universe et pas le vpinmame de vpforum
MessageSujet: Re: [TABLE] Tron Legacy   Mar 27 Mar 2018 - 19:59
Il ne faut pas dézipper la rom [Vous devez être inscrit et connecté pour voir ce lien].
MessageSujet: Re: [TABLE] Tron Legacy   Mer 28 Mar 2018 - 21:34
Sujet déplacé dans la bonne section.
Sujet fusionné avec sujet traitant de la table déjà existant.
mikuslegrand
MessageSujet: Re: [TABLE] Tron Legacy   Mer 28 Mar 2018 - 22:27
je l'avais juste décompressé pour ouvrir le fichier bin.
Par contre j'ai résolu mon problème en installant le dernier pack ( pack 4)de VPX.
Je l'ai installé et transféré mes tables dedans et tout fonctionne à merveille après avoir réglé quelques détail sur la position du DMD et du backglass.
encore merci pour tout  [Vous devez être inscrit et connecté pour voir cette image] .
[TABLE] Tron Legacy
