 [RÉSOLU] Zedmd
swan38
Département : isere
[RÉSOLU] Zedmd Empty
MessageSujet: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMar 6 Juin 2023 - 20:22
bonjour
j ai actuellement un zedmd qui affiche bien le logo zedmd (tuto zedmd suivie a la lettre mainte et mainte fois)
quand je lance ma table sur vpx le logo zedmd s éteint et plus rien
 [6] 2023/06/06 20:02:14.652  INFO | Successfully loaded config from C:\Visual Pinball\VPinMAME\DmdDevice.ini.
 [6] 2023/06/06 20:02:14.723  INFO | Determined color path from assembly path: C:\Visual Pinball\VPinMAME\altcolor
 [6] 2023/06/06 20:02:15.870  WARN | Could not parse time zone Paris, Madrid.
 [6] 2023/06/06 20:02:15.885  INFO | Starting VPinMAME API 2.1.2 through VPinballX.exe.
 [6] 2023/06/06 20:02:15.885  INFO | Assembly located at C:\Visual Pinball\VPinMAME\DmdDevice.dll
 [6] 2023/06/06 20:02:15.885  INFO | Running in C:\Visual Pinball\Tables
 [6] 2023/06/06 20:02:15.885  INFO | [vpm] Open(0)
 [6] 2023/06/06 20:02:15.885  INFO | [vpm] Set_4_Colors_Palette(0, #000000, #0600D6, #E10FC1, #FF5820)
 [6] 2023/06/06 20:02:15.885  INFO | Setting palette to 4 colors...
 [6] 2023/06/06 20:02:15.885  INFO | [vpm] PM_GameSettings(0, simpprty, 1)
 [6] 2023/06/06 20:02:15.885  INFO | Enabling game colorization
 [6] 2023/06/06 20:02:15.885  INFO | Setting game name: simpprty
 [6] 2023/06/06 20:02:15.885  INFO | Setting color: #FFFF5820
 [6] 2023/06/06 20:02:15.896  INFO | No palette file found at C:\Visual Pinball\VPinMAME\altcolor\simpprty\pin2dmd.pal.
 [9] 2023/06/06 20:02:15.896  INFO | Starting ZeDMD frame thread.
 [6] 2023/06/06 20:02:16.516  INFO | ZeDMD device not found
 [6] 2023/06/06 20:02:16.516 ERROR | No renderers found, exiting.
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMar 6 Juin 2023 - 20:57
Hello
Tu as bien vérifié que ton esp est bien apparent dans le gestionnaire de périphériques?
swan38
Département : isere
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMar 6 Juin 2023 - 21:07
[6] 2023/06/06 21:05:42.313  INFO | Successfully loaded config from C:\Visual Pinball\VPinMAME\DmdDevice.ini.
 [6] 2023/06/06 21:05:42.392  INFO | Determined color path from assembly path: C:\Visual Pinball\VPinMAME\altcolor
 [6] 2023/06/06 21:05:43.541  WARN | Could not parse time zone Paris, Madrid.
 [6] 2023/06/06 21:05:43.541  INFO | Starting VPinMAME API 2.1.2 through VPinballX.exe.
 [6] 2023/06/06 21:05:43.541  INFO | Assembly located at C:\Visual Pinball\VPinMAME\DmdDevice.dll
 [6] 2023/06/06 21:05:43.541  INFO | Running in C:\Visual Pinball\Tables
 [6] 2023/06/06 21:05:43.557  INFO | [vpm] Open(0)
 [6] 2023/06/06 21:05:43.557  INFO | [vpm] Set_4_Colors_Palette(0, #000000, #0600D6, #E10FC1, #FF5820)
 [6] 2023/06/06 21:05:43.557  INFO | Setting palette to 4 colors...
 [6] 2023/06/06 21:05:43.557  INFO | [vpm] PM_GameSettings(0, godzilla, 1)
 [6] 2023/06/06 21:05:43.557  INFO | Enabling game colorization
 [6] 2023/06/06 21:05:43.557  INFO | Setting game name: godzilla
 [6] 2023/06/06 21:05:43.557  INFO | Setting color: #FFFF5820
 [6] 2023/06/06 21:05:43.557  INFO | Loading palette file at C:\Visual Pinball\VPinMAME\altcolor\godzilla\pin2dmd.pal...
 [6] 2023/06/06 21:05:43.557  INFO | Loading virtual animation file at C:\Visual Pinball\VPinMAME\altcolor\godzilla\pin2dmd.vni...
 [6] 2023/06/06 21:05:43.604  INFO | Loaded animation set VPIN v4, 62 animation(s)
 [6] 2023/06/06 21:05:43.604  INFO | Animation Dimensions: 128x32
 [6] 2023/06/06 21:05:43.604  INFO | ScaleToHd = False
 [9] 2023/06/06 21:05:43.604  INFO | Starting ZeDMD frame thread.
 [6] 2023/06/06 21:05:44.230  INFO | ZeDMD device not found
 [6] 2023/06/06 21:05:44.230 ERROR | No renderers found, exiting.
swan38
Département : isere
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMar 6 Juin 2023 - 21:08
merci pour ta réponse et oui jai bien check le gestionnaire port com5
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMar 6 Juin 2023 - 21:13
Tu as mis à jour avec l'updater? Dmdext est en dernière version?
swan38
Département : isere
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMar 6 Juin 2023 - 21:43
ou ce trouve t-il?
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMar 6 Juin 2023 - 21:46
Dans le tuto mis a jour
swan38
Département : isere
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMar 6 Juin 2023 - 21:50
non jai pas encore check ca je vais tester ca demain je reviendrais aux nouvelles
en tout cas merci de ton aide je débute dans le monde du cab
zedrummer aime ce message
swan38
Département : isere
MessageSujet: Résolu   [RÉSOLU] Zedmd EmptyMer 7 Juin 2023 - 18:56
je viens au nouvelle mon esp était en version 2.1 je lui ai mis la 3.2.4 et ces bon tout fonctionne
swan38
Département : isere
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyMer 7 Juin 2023 - 18:57
je te remercie infiniment
MessageSujet: Re: [RÉSOLU] Zedmd   [RÉSOLU] Zedmd EmptyVen 9 Juin 2023 - 9:47
Ah ben super, parfait, bonne continuation
[RÉSOLU] Zedmd
» [RÉSOLU] Compatibilidad zedmd
» [RÉSOLU] Zedmd problem
» [EN COURS] Zedmd
» [RÉSOLU] ZeDMD: device not found (parfois)
» [RÉSOLU] ZeDMD: moitié basse colorisée en vert
Pincab Passion :: Univers du Pincab :: ZeDMD & Serum-
