 [WIP 96%] Mon premier pincab : transfomation zaccaria
nicofab18
leopold
Mick_03
jimenez
tortuegenial
samsmile
tyson171
sebx
jlog06
kakou
25 participants
Aller à la page : Précédent  1, 2, 3, 4, 5 ... 10, 11, 12  Suivant
kakou
kakou
Département : 18
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Empty
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyDim 23 Avr 2017 - 12:18
Voici le code wemos qui a l'air de fonctionner chez moi (je recois bien des paquets de dof), pour la suite, j'attends d'avoir des ledstrips adressables, car la je test un peu dans le vide Smile
Code:
  SmartShow AirPixel ONE - Single Universe ArtNet to WS2812 Driver - For Wemos D1
  You can set the Device IP, and universe number below
  Works perfectly with Jinx LED software
#include <ESP8266WiFi.h>
#include <WiFiUdp.h>
#define WSout 5  // Pin D1
#define WSbit (1<<WSout)
// ARTNET CODES
#define ARTNET_DATA 0x50
#define ARTNET_POLL 0x20
#define ARTNET_POLL_REPLY 0x21
#define ARTNET_PORT 6454
#define ARTNET_HEADER 17
WiFiUDP udp;
uint8_t uniData[514];
uint16_t uniSize;
uint8_t hData[ARTNET_HEADER + 1];
uint8_t net = 0;
uint8_t universe = 0;
uint8_t subnet = 0;
const char* ssid    = "XXXXXX";
const char* password = "XXXXXXXXXXXXXX";
IPAddress local_ip(192, 168, 4, 123);
IPAddress gateway_ip(192, 168, 4, 254);
IPAddress subnet_ip(255, 255, 255, 0);
void setup() {
        Serial.begin(115200);
        delay(10);
        Serial.println();
        Serial.println();
        Serial.print("Connecting to ");
        Serial.println(ssid);
        WiFi.begin(ssid, password);
        WiFi.config(local_ip, gateway_ip, subnet_ip);
        while (WiFi.status() != WL_CONNECTED) {
                delay(500);
                Serial.print(".");
        udp.begin(ARTNET_PORT); // Open ArtNet port
        Serial.println("");
        Serial.println("WiFi connected");
        Serial.println("IP address: ");
        Serial.println(WiFi.localIP());
        pinMode(WSout, OUTPUT);
void ICACHE_FLASH_ATTR sendWS() {
        uint32_t writeBits;
        uint8_t bitMask, time;
        os_intr_lock();
        for (uint16_t t = 0; t < uniSize; t++) { // outer loop counting bytes
                bitMask = 0x80;
                while (bitMask) {
                        // time=0ns : start by setting bit on
                        time = 4;
                        while (time--) {
                                WRITE_PERI_REG( 0x60000304, WSbit ); // do ON bits // T=0
                        if ( uniData[t] & bitMask ) {
                                writeBits = 0; // if this is a '1' keep the on time on for longer, so dont write an off bit
                        else {
                                writeBits = WSbit; // else it must be a zero, so write the off bit !
                        time = 4;
                        while (time--) {
                                WRITE_PERI_REG( 0x60000308, writeBits ); // do OFF bits // T='0' time 350ns
                        time = 6;
                        while (time--) {
                                WRITE_PERI_REG( 0x60000308, WSbit ); // switch all bits off  T='1' time 700ns
                        // end of bite write time=1250ns
                        bitMask >>= 1;
        os_intr_unlock();
void loop() {
        if (udp.parsePacket()) {
                Serial.print("Arnet packet :)");
                udp.read(hData, ARTNET_HEADER + 1);
                if ( hData[0] == 'A' && hData[1] == 'r' && hData[2] == 't' && hData[3] == '-' && hData[4] == 'N' && hData[5] == 'e' && hData[6] == 't') {
                        if ( hData[8] == 0x00 && hData[9] == ARTNET_DATA && hData[15] == net ) {
                                if ( hData[14] == (subnet << 4) + universe ) { // UNIVERSE
                                        uniSize = (hData[16] << 8) + (hData[17]);
                                        udp.read(uniData, uniSize);
                                      Serial.print("hData :");
                                        for (int i=0;i<18;i++)
                                          Serial.print(hData[i]);
                                        Serial.println("");
                                        /*Serial.print("uniData :");
                                        for (int i=0;i<514;i++)
                                          Serial.print(uniData[i]);
                                        Serial.println("");
                                        Serial.print("ArtNet packet RX Uni 0 - size:");
                                        Serial.println(uniSize);
                                        sendWS();
                        } // if Artnet Data
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 16:41
Installation d'un knocker de recupération et d'une cloche/bell (en fait une ancienne sonnette)
Testé sous Williams Fire, la sonnette fait un peu sursauté quand elle se met en route, mais c'est du plus belle effet Smile
Knocker avant decapage
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2044
La sonnette
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2043
Le knocker décapé/installé
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2042
Le cablage actuel
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2045
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2046
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2047
Le pinball actuel
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2048
Modérateur + Team PP
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 17:57
bravo
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 30674711
https://www.pinballmag.fr
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 19:55
merci @aetios
j'essai de créer un combo pour que ma sonnette sonne quand le knocker claque
Donc dans dof, j'ai créer une combo "combo1" mono avec le "knocker" et le "bell" dedans
Par contre je ne comprends pas la suite, il faut assigner "combo1" a un port de la ledwiz-arduino ? mais moi j'ai deja un port pour le knocker et un pour le bell ??? ou alors c'est juste pour mettre deux toys sur le même port ?
Je suis sur que @mariopourlavie peux m'aider A la tienne
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 20:59
Très bon travail @Kakou  [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 21:21
Pourquoi tu t'embetes , tu actives une seconde sortie knocker sur un autre port et se sera ta sonnette qui sera branchee dessus .Les deux s'activeront ensemble lorsque le knocker claquera.
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 21:35
Si je met knocker comme nom sur mon bell, je n'aurai plus le bell
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 21:40
Re,
Phili50 a presque raison, si tu n'as pas besoin de la cloche sur la table taxi...
Voilà comment je vois les choses.
de ce que j'ai compris le combo permet de déclencher simultanément deux toys, qu'ils reçoivent l'ordre de l'un ou de l'autre.
Du coup Cela n'ira pas si tu veux les garder uniques, surtout la cloche...
Moi je ferais différemment, je prendrais l'idée de phili50 mais sur cette deuxième sortie je mettrais une diode "anti retour" comme ça ta cloche sonnera avec le knocker mais quand la cloche est déclenchée par le dof dans taxi par exemple, alors il sera seul...
Si tu veux un schéma dis le moi...
Mais tu as eu une super idée là, et ça vaut le coup de sy pencher dessus [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302
Ha oui, bravo pour les travaux sur le pincab [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 22:21
@mariopourlavie oui je veux garder la cloche, pour taxi notamment, et je voulais savoir si c'etait possible de le faire dans modification de ma carte directement dans dof. j'avais pensé a connecter la cloche sur le knocker mais je trouvé pas ca très propre Smile (surtout que ma sonnette est en 220V, donc je l'ai isoler du reste avec un relay et son propre circuit)
Sinon je pense quand modifiant le fichier dofmachin.ini ca doit passer aussi
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyJeu 27 Avr 2017 - 22:32
rire  Moi je suis de la vieille école, mais si vous savez coder et programmer pour que vos arduino reconnaissent les commandes du DOF, moi je ne peux pas suivre  rire  Je ne pourrais le faire que comme la moutarde, à l'ancienne  lol!
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyVen 28 Avr 2017 - 12:09
Sans entrée dans l'arduino, j'ai vu que quand tu configure DOF, tu télécharges les fichiers de config (.ini) de la ledwiz ... et dedans, tu as la listes des roms et les toys a utiliser en fonction de l'événement pour chaque table (c'est comme ca que j'ai trouvé les tables qui utilisent la sonnette). Donc je pensai directement modifier ce fichier en ajoutant la sonnette quand le knocker est utilisé Smile
Enfin c'est juste histoire de l'utiliser car sinon y'a que 10-15 tables ou elle est utile Smile
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyVen 28 Avr 2017 - 12:19
Ha ok [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302 Alors je vais te suivre, car si tu y arrives, alors cela m'intéresse le comment faire, car j'ai des modifs perso que je voudrais faire [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3746298195
Juste une précision, dans le dof config tool il y a un onglet "stats" pour savoir dasn quelles tables sont utilisés les toys [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302
Et sur L'onglet "Tables configs" tu peux aussi modifier supprimer / ajouter des éléments pour chaque table [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyVen 28 Avr 2017 - 13:33
Merci pour l'info sur les stats, ca m'évitera de farfouiller dans les fichiers la prochaine fois Smile
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyVen 28 Avr 2017 - 21:47
J'en avais mare du bruit de mes ventilos ( il faudrait que j'en achète des vraiment silencieux)
En attendant :
 1 arduino nano + 1 carte relay 4 ports + 1 petit bout de code = les ventilos s'allument pendant 5 minutes quand la caisse dépasse les 25°
Ca fait déjà moins de bruit Smile
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyVen 28 Avr 2017 - 22:04
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 4216826579
Comment ça marche ces arduinos ? Tu peux m'expliquer avec un schéma ? Parce que moi j'ai commandé des trics à l'ancienne [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3746298195 un thermostat mécanique [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 773715342 mais je trouverais sympa de pouvoir ajouter mon premier arduino et du code lol!
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyVen 28 Avr 2017 - 22:39
Moi j'utilise
- une arduino nano a 2.30€ Smile arduino nano
- une carte relay 4 ports pour pouvoir contrôler 4 ventilos
- je peux aussi contrôler la vitesse des ventilos pour les ventilateurs 4 fils
Connecter la carte relay sur l'arduino :
GND, 5V sur GND,5V de l'arduino
S1,S2,S3,S4 sur D4,D5,D6,D7 de l'arduino
Connecter un DHT22 (temperature/humidité) sur l'arduino
+ sur 5V de l'arduino
GND sur GND de l'arudino
DATA sur D2 de l'arduino
j'ai 1 ventilo 4 fils que j'ai connecté sur D3
Connecter sur les relay le +12V et le fil + des ventilos (1 par relay), et le - en direct sur la masse l'alim
Voici le code actuelle ultra-simpliste que j'utilise, a envoyer sur la carte arduino connecté en USB au PC (via l'IDE arduino) :
Code:
#include <Adafruit_Sensor.h>
#include "DHT.h"
#define DHTPIN  2
#define DHTTYPE DHT22
DHT dht(DHTPIN, DHTTYPE); //déclaration du capteur
int pwmPin     = 3; // digital pin 3
int oldfanspeed = 0;
#define FAN1 4 // VENTILO CENTRAL (INJECTION)
#define FAN2 5 // VENTILO ARRIERE (EXTRACTION)
#define FAN3 6
#define FAN4 7
#define ON HIGH
#define OFF LOW
long previousMillis = 0;
long interval = 300000;
void setup()
        /* Initialisation du port série */
        dht.begin();
        // generate 25kHz PWM pulse rate on Pin 3
        pinMode(pwmPin, OUTPUT); // OCR2B sets duty cycle
        // Set up Fast PWM on Pin 3
        TCCR2A = 0x23; // COM2B1, WGM21, WGM20
        // Set prescaler
        TCCR2B = 0x0A; // WGM21, Prescaler = /8
        // Set TOP and initialize duty cycle to zero(0)
        OCR2A = 79; // TOP DO NOT CHANGE, SETS PWM PULSE RATE
        OCR2B = 0; // duty cycle for Pin 3 (0-79) generates 1 500nS pulse even when 0 :
        // Initialisation des ventilateurs
        setFanSpeed(0);
        setFanSpeed(79);
        setFanSpeed(0);
        pinMode(FAN1, OUTPUT);
        pinMode(FAN2, OUTPUT);
        pinMode(FAN3, OUTPUT);
        pinMode(FAN4, OUTPUT);
        for(int i=FAN1; i<=FAN4; i++) {
                digitalWrite(i,ON);   // Turns ON Relays 1
                delay(200);
        delay(2000);
                delay(200);
                digitalWrite(i,OFF); // Turns Relay Off
   speed vitesse (0-79)
void setFanSpeed(int speed) {
        OCR2B = speed;
        delay(200);
void loop()
        /*        unsigned int x;
                // ramp up fan speed by increasing duty cycle every 200mS, takes 16 seconds
                for(x = 0; x < 80; x++) {
                        OCR2B = x; // set duty cycle
                        delay(200);
        // Lecture du taux d'humidité
        float h = dht.readHumidity();
        // Lecture de la température en Celcius
        float t = dht.readTemperature();
        // Stop le programme et renvoie un message d'erreur si le capteur ne renvoie aucune mesure
        if (isnan(h) || isnan(t)) {
                Serial.println("Echec de lecture !");
                return;
        Serial.print("Humidite: ");
        Serial.print(h);
        Serial.print(" %\t");
        Serial.print("Temperature: ");
        Serial.print(t);
        Serial.println(" *C ");
        // FAN speed 25C=>0 40=>80
        float fanspeedt = ((t - 25)/15)*80;
        int fanspeed = (int)fanspeedt;
        if (fanspeed < 0)
                fanspeed = 0;
        if (fanspeed > 79)
                fanspeed = 79;
        if (oldfanspeed != fanspeed) {
                Serial.print("FAN SPEED : "); Serial.println(fanspeed);
                setFanSpeed(fanspeed);
                oldfanspeed = fanspeed;
        unsigned long currentMillis = millis();
        if (t>25){
          previousMillis = currentMillis;
                  delay(200);
                  digitalWrite(i,ON); // Turns Relay Off
        if(currentMillis - previousMillis > interval) {
                  delay(200);
        delay(10000);
Si ca intéresse, je peux faire un tuto et forunir un .hex tout pret a mettre sur l'arduino avec le contrôle, par exemple, d'au plus 6 ventilos et 6 ventilos a vitesse variable (4pins)
Pour la suite, je vais améliorer mon code en ajoutant :
- allumer 1, puis 2, puis 3, puis 4, puis ... ventilos en fonction de la temperature
- faire sonner un buzzer en cas de temperature extreme
- des boutons pour forcer l'alumage/extinction des ventilos
- lire la vitesse du ventilo via le 3eme fils
- afficher les infos (vitesse, temperature, ...) sur un ecran  a 4€ ecran
matvaut aime ce message
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyVen 28 Avr 2017 - 22:44
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302  ha oui ça me plaît ça [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302
Moi un tuto complet je veux bien. Ce serait un super plus pour nos pincab Very Happy Donc merci d'avance si tu veux te lancer .
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyVen 28 Avr 2017 - 22:51
ok pas de soucis, je ferai un tuto complet Smile
sebx
Département : 28
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptySam 29 Avr 2017 - 0:27
+1 intéressé  [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyMer 3 Mai 2017 - 22:37
Ajout de 3 leds RGB dans les 3 coin-door avec combo DOF sur les flashers (Ca rends mieux sous PBFX2 DOFLinx)
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyMer 3 Mai 2017 - 22:43
Re,
C'est une idée quelle bonne [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302 bravo Very Happy
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptyMer 3 Mai 2017 - 22:59
Tu as la même porte zaccaria en plus Smile
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptySam 6 Mai 2017 - 16:05
Ajout de quelques photos de ma WIP borne
kakou
kakou
Département : 18
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptySam 13 Mai 2017 - 19:06
Debut de cablage du fronton :
- ajout des 2 haut-parleur pioneer recu, cablage (mais il me manque encore l'ampli)
- fixation de la carte pour le DMD (avec un cable HUB75 de 50cm, j'ai testé 1m, mais y'avais trop de perturbation)
- ajout d'une 3eme arduino mega-ledwiz pour controler ce qu'il y aura dans le fronton
- 1 carte avec 2 ULN, 1 carte avec 4 mosfet
- ajout des 2 gyrophare recu ce matin
Ce qui viendra ensuite :
- 2 ledstrip + 2 RGB pour les enceintes (a la @mariopourlavie)
- 1 ledstrip undercab (Vous mettez juste de bande ou vous faites le tour du bas du caisson ?)
- 1 ledstrip derriere-cab (surement combo flasher+undercab)
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2049[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2053[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2052[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 Img_2050
MessageSujet: Re: [WIP 96%] Mon premier pincab : transfomation zaccaria   [WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 EmptySam 13 Mai 2017 - 20:51
[WIP 96%] Mon premier pincab : transfomation zaccaria - Page 4 3253257302 Quand ça avance ça ne recul pas, c'est cool, beau travail.
Pour ce qui est de l'undercab, je pense que chacun fait à son goût Very Happy perso, j'ai fait le tour complet Wink
Page 4 sur 12Aller à la page : Précédent  1, 2, 3, 4, 5 ... 10, 11, 12  Suivant
» [WIP]Mon premier pincab
» [40%] Mon premier pincab
» [WIP] Deuxième mini pincab de Sebmad: Zeslimpin
» [WIP] Mon premier pincab 24"
» [WIP] Fin de mon premier Pincab
